Is it possible to run VBA macros stored in the Personal.xls file or in .bas files from a LabView vi?
I am running LabView6.1 and am trying to work with macros in Excel and Word. I am using the generic ActiveX controls (i.e. not the Microsoft toolkit) and would like to be able to run macros to exchange data between Word and Excel without user-input. Strange thing is that when I open up an instance of Excel from a LabView vi, I can't see the macros stored in the Personal.xls file, which should be available to every workbook whenever Excel is opened. I also don't see a way to import macros into a spreadsheet from an external .bas file without the user doing it manually in Excel. The goal is to not tie a vi to a specific spreadsheet or Word document, but to keep it as ge
neral as possible. Any hints?
(3,174 Views)
Robert M.,
Yes this is possible because our Office toolkit does this. Importing a .bas file can be done by using an Excel._Workbook to a VBProject to a VBComponents object and calling the Import method.
As for why you cannot see items in Personal.xls, I am not sure. All you are doing is using ActiveX, so if Microsofts' ActiveX control does not let you see the file, I would ask them to see if they have any examples on how to do this. I tried searching the Help in Excel 2000 for personal.xls and I came up with nothing. I did not know that you could have globally available workbooks. Could you point me to more information on that, or am I on the wrong track here?
Randy Hoskin
http://www.ni.com/ask
(3,174 Views)
Sorry, I should have said I am using Office 97. Personal.xls is a way to store macros that you want to be available to all workbooks. Perhaps they have changed things for Office 2000, though.
(3,175 Views)
I am having the same problem.  I have used personal.xls macros from other programs, but I am not sure how to tell labview how to find personal.xls, since you can't actually point to the file (I think it's hidden in a dll or something).  I can't say I have a solution, just that you are not the only one.
(3,086 Views)
