10-22-2015 07:07 AM
I changed the admin password of the Application Web server and forgot it... Is there a way of resetting passwords of the Application Web Server please?
10-26-2015 08:54 AM
There is a method to reset your password, however unfortunatley this information is only available on a case-by-case basis, so I recommend getting in touch with your local NI branch.
If you do not have access to support, you will have to explain that the nature of the problem mean't that we could not make it public on the forums, and someone should be able to help you.
Tom
NI UK
