Is it possible to really deactivate a button?
I am having a few buttons in my vi, that trigger different event case structures. due to the nature of the system events have to be done in a specific order - so I want to disable the buttons are not allowed to be used at the moment, because for example: it hasn't been enough data collected.
At the moment I am using the button property disabled. But the buttons are only grayed out, you are still able to push them. So it still triggers the event, which causes the vi to hang, because it's waiting for some data which it's not able to retrieve.
Is it possible to really disable buttons?
Message 1 of 11
(3,968 Views)
What kind of event are you using for the disabled button? Mouse Down or Value Change? If Mouse Down, change it to Value Change.
Message 2 of 11
(3,960 Views)
sthu,
I put a button on the front panel, set the Enabled State property to Disabled (or Disabled & grayed - either work fine) and put a Case Structure in the main loop to handle the button press.  The Case Structure does not fire because the button state cannot be changed from false to true.  If you are using an Event Structure in your loop to handle front panel events, you should look for the Value Change event.  If you hooked up a handler for the Mouse Down event, the event will still fire even though the button is disabled.
-cb
Message 3 of 11
(3,957 Views)
What event are you waiting on?
I suspect 'Mouse Down'. Try using 'Value Change' and see if that helps...
Dennis is FAST. I'm only happy that my suggestion was the same as his. Smiley Very Happy
Message Edited by Phillip Brooks on 11-28-2007 01:14 PM
Message 4 of 11
(3,956 Views)
The problem is that I just want to trigger the events when the button is pressed, but the button should return to its old state againg.
I hit the button - event is trigger - button returns to it's old position.
If I use the value change condition, the event triggers twice. one time when the button is hit and second time when the button is released. that would be a big problem...
Message 5 of 11
(3,934 Views)
You could compare the New Value to True within the event case before executing your code, or you could experiment with the mechanical action (use Latch when released)
Message Edited by Phillip Brooks on 11-28-2007 02:22 PM
Message 6 of 11
(3,927 Views)
It sounds like you are also using the wrong mechanical action for the button. Try Latch When Released.
p.s. Trying to guess what is in your VI is not always the most efficient way to troubleshoot. Posting the actual VI or an example that demonstrates the problem is the fastest way to see why something doesn't work and how it should be changed.
Message 7 of 11
(3,926 Views)
 ok, thanks - I think I narrowed down the problem. The Buttons in my actual VI seem to be broken. No matter how I set their properties, the way how they react doesn't change... I'll try to replace them, though it will be a lot of work and see if it fixes it.
Message 8 of 11
(3,914 Views)
Buttons don't get 'broken'. Why don't you just post the VI?
Message 9 of 11
(3,909 Views)
guess what? I replaced one button and it works.. these are the days when I just start to dislike labview 😕
will be having fun deleting and creating buttons now...
Message 10 of 11
(3,907 Views)
