Is it possible, to let labview control a smaller curcuit, through a PCI-6023E
I want to have Labview make, an output signal through a PCI-6023E card. It has ro be a constants signal, it is used to control a smaller curcuit.
(2,529 Views)
Yes, of course. You've got all of the Analog Output and Digital I/O functions in the Data Acquisition palette.
(2,529 Views)
Hello;
You certainly can do that. The only thing you need to double check is if the external circuitry doesn't sink too much current, and if that current value is within the value specified by the 6023.
Regards
Filipe A.
(2,529 Views)
