Is it possible to import simulink blocks into labview
I was wondering if it is possible to import the MATLAB/simulink blocks into labview.
thanks,
Baran.
Message 1 of 8
(5,644 Views)
Hi Baran,
There is no way to directly import any of the programing blocks from The MathWorks, Inc. Simulink® software into LabVIEW.
However if you wanted to use your own code that you programed using The MathWorks, Inc. Simulink® environment in LabVIEW, we do have the NI Simulation Interface Toolkit that is now part of the Model Interface Toolkit, which you can use.
<Brian A | Applications Engineering | National Instruments>
Message 2 of 8
(5,634 Views)
Thanks.
Message 3 of 8
(5,628 Views)
Baran,
Yes, you can convert them. The Control Design and Simulation Module can convert .mdl files to LabVIEW VIs.
https://www.ni.com/docs/en-US/bundle/labview-control-design-and-simulation-module/page/lvsimconcepts...
Hope that helps.
Damon
Message 4 of 8
(5,619 Views)
Is "Control Design and Simulation Module" same as "Control and simulation" add-on which is in the NI Developer Suite (labview professional bundle)?
Message 5 of 8
(5,607 Views)
Also do I need to purchase Matlab Real-time workshop for that?
Thanks.
Message 6 of 8
(5,603 Views)
Hi Baran,
Yes, they are the same. No, you do not need Matlab Real-time to use the Simulation Model Converter.
Cheers,
Damon
Message 7 of 8
(5,593 Views)
Thanks Damon.
Message 8 of 8
(5,590 Views)
