Is it possible to havedrop down lists in cells of a Multi Column List box(not Table)?
I was using a muticolumn listbox(not table,for table i have example code,and problem is that i was not getting active cell position for Multi column listbox) with 5 columns.In third column,i want to generate a ring control,generate in the sense,whenever user clicks on any cell of third column of multicolumn listbox(not table),the ring control should pop up.The thing is that i need to use only one ring control and whenever user clicks on any cell of a third column,this ring control should pop up.How can i achieve this,anyone please help me,
Naresh.N
(2,553 Views)
Hi, Naresh,
For starting point you can read this: Table with Drop Down Items
Andrey.
(2,546 Views)
