Is it possible to have a floating point representation in an array in LabVIEW?
Could anyone be able to tell me how I would go about creating a part of a Vi that would create a user defined N random arrays of user defined length consisting of floating point representation?
The values in the array cannot be limited to 0 and 1.
Alan Homer
(2,387 Views)
Sorry, I don't understand what you want,
N random arrays?  You can build an array of required length, bundle it to a cluster and repeat this X times (Depending on how many arrays you need).  Each cluster can then in turn be grouped to an array, whereby each array retains its own length.
You can easily define an array as an array of floating point numbers.  Is this what you mean? (See picture)
I also don't quite understand what the values 0 and 1 have to do with your question as a whole.....
Trying to help
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,380 Views)
Sorry, it was poorly explained but yes, you got the right idea, I wanted N random arrays of floating point numbers.
Alan Homer
(2,363 Views)
