The good thing of Installer (created by application Builder) is that it also integrates LabView Runtime Engine along with supports like Serial port support, Port I/O support etc. Due to which one can install the application developed by Labview on any system wheather that contains Labview or not, as the engine required by that application also gets installed.
But problem with my application is that it uses DAQmx related stuff, so I have to install DAQmx 8.0 prior to running my application installer on any system. Is it possible that the DAQmx related stuff required by my application also gets install through same installer as it installs LabView Runtime Engine, so that the distribution of my application donot require the complete installation of DAQmx.
