Is it possible to do a 3D contour plot with irregular x and y values?
I need to plot an x,y,z data as a 3D contour plot. But my x and y values are not regularly separated. Is it possible to do this with Labview 7.1?
Hamza
(2,654 Views)
Hi
This should be no problem. Have a look at the attached vi. There are three arrays (x,y,z) where each corresponding value (for instance x(1/1), y(1/1) and z(1/1)) define a point on the plot. It doesn't matter if the values are regularly spaced or not.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,639 Views)
