Is it possible to display my measurements on my iPad 3?
is it possible to display my measurement on my iPad3?
I am having cDAQ 9191 and NI-9234, I would like to see my measurement on my iPad3.
Q1: do I need to have a MacBook Pro to do this application?
Q2: do I need to buy extral license to my Labview developer suite?
Q3: is there a step by step manual for displaying measurement on iPad3?
(3,093 Views)
Accepted by topic author Ihab
(3,090 Views)
(3,078 Views)
Thank you for your prompt reply.
I followed every thing.
I am still missing some connection to the network
I receive : connection error
Invalid Server: Cannot connect to server. Check the address and wireless connection and try again
I tried my router address
I tried the address that appeared in the deployment status windows after  deploying the library contains my shared library.
(3,054 Views)
Thanks for your support.
I managed to apply the example, and tried to access my  measurement Data from cDAQ 9191 with NI 9234 as per attached project and vi.
Please review it and tell me what is wrong. The problem is after  the Web method connects successfully, I have seen the Web Link icon turned green.  But To link my  Poll to the Graph  indicator I should  select the adorner of the variable I want to link but this adorner never appeared this time on the iPad Dashboard.
(3,022 Views)
Thanks this has been solved with the Getting started example but when applied on cDAQ 9191 with NI 9234 it did not work well. Please see my previous post with the vi attached. Thanks
(3,021 Views)
If you're still having issues with this - the VI that you attached looks like it's outputting a waveform in the web service, which isn't supported by Data Dashboard. The in-app help for the iPad application has details on what data types we support - essentially, for graphs, your choices are 1D array of numerics (except I64/U64), and 1D array of points (where "point" is a cluster of 2 supported numerics). Data Dashboard will not show you web service output adorners for the terminal types that we don't support.
(2,952 Views)
