Is it possible to connect NI USB 8473 (High speed CAN) to LabVIIEW RT directly
Hi all,
I am using Desktop PC as LabVIEW Real-Time Target. Is it possible to connect NI USB 8473 (High speed CAN) to RT's USB port directly?, sothat I can see it under "Network environment" tab of M&A Explorer window.
Thank you,
Ravinder
(2,698 Views)
hello ravinder,
at the moment you cannot access USB devices for DAQ or CAN on RT systems.
you can use USB only for storage devices.
http://forums.ni.com/ni/board/message?board.id=170&message.id=316305
regards,
robert h
NI germany
(2,676 Views)
Hi Robert.....
Thank you very much for your response. Then I shall go for PCI or PXI CAN inteface......
Thank you....
Ravinder
(2,669 Views)
