Is creating multiple indicators on a front panel the best way to go?
I have a control panel with over 40 buttons that I would like to create a labview test
for that will display which button is pressed.
Would this be easiest to create a front panel with individual indicators for each or
is there a simpler/ more efficient way to do this so that the front panel gives a visual
indication of the actual button pressed and its location?
Because the control panel is a serial RS232 line but was designed for use with a certain
assembly, I wish to simplify this so I do not need to include as much hardware and have
decided to use and arduino to  communicate to the control panel and hen use labview to
communicate to the arduino via the USB port on the PC.
Also, any thoughts on how to best parse the data from the arduino to enable the indicator on the front panel
is appreciated.
thanks
Message 1 of 17
(3,880 Views)
You need to provide more information. For example, how are the buttons arranged? If they're in a grid, you might be able to use an array instead of individual buttons. If the buttons are distributed unevenly and you want a front panel that reflects the physical position of the buttons, then you'll need individual indicators (which could be wrapped in an enormous cluster, if for some reason that's more convenient). If you just need to convey information about which button is pressed, you could use a single string indicator and change the text.
Message 2 of 17
(3,851 Views)
My first thought was just having a string indicator instead of the large number of indicators.  I would probably also have a large string indicator to show a log of the states that you recieved.
Message 3 of 17
(3,839 Views)
An array of Boolean indicators (round lamp) is a easy and simple way to show it.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 17
(3,830 Views)
Thank you for the suggestions...
The control panel buttons are not evenly spaced so a grid might not work.
If there is a way, I would like to place a bitmap of the control panel on the front panel and then
make indicators (an array of Boolean indicators might work well) and place these over the bitmap where the
control panel buttons.
I think I know how to make an array of indicators but not sure how I would parse the serial data to enable the
indicators. Would this require a look up table or a bunch of string compares?
Message 5 of 17
(3,804 Views)
Might be a good idea to do up a mock up of your desired front panel using paint/powerpoint/photoshop etc. so we can best suggest what approach to take...
Strokes
Message 6 of 17
(3,795 Views)
I actually created a front panel this morning with indicators as seen below:
Message 7 of 17
(3,775 Views)
Kinda neat - I see a keypad and some cursor controls.  What is it?  🙂
Bill
CLD
(Mid-Level minion.)
Message 8 of 17
(3,762 Views)
It is a control panel used on medical devices and I want to put together an application to show which button
was pressed...
Message 9 of 17
(3,753 Views)
I would consider a cluster.  I would probably use some sub-clusters as well so that similar buttons are grouped into individual clusters (like the buttons that look like a keypad arrangement), and the clusters grouped into a larger cluster.
Make the cluster a typedef.  If you make a strict TypeDef, then you can lock in the appearance of the buttons (location, size, ...)
Message 10 of 17
(3,750 Views)
