Is anyone running LabVIEW on windows 2003 server?
I am looking at buying a server PC and running windows 2003 server OS for my data acquisition system. Has anyone run LabVIEW on windows 2003 server? Why you ask:
Reliability (redundant power supplies, memory, hard drives etc)
Remote acces (through client tools)
Security, mountability, etc, etc....
John
(2,998 Views)
Greetings:
I have run Labview 7 on 2003 server with no apparent bugs. You probably already know that most of the services and ports are off by default in 2003 (which is why it is more secure), so if, for example, datasocket doesn't work, be sure your firewall is configured to allow it.
Eric
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,998 Views)
Eric,
Thanks for the reply. Any configuration advice that will get things up and running faster would be appreciated. I figured things would have to be tweeked in server to use all the options in LV. You haven't noticed any problems with running multiple client connections have you?
John
(2,998 Views)
