Is There Any Way to Disable an Item of an Enum Constant with Scripting?
The Disabled Items[] property of an Enum strict typedef doesn't propagate to a constant when the constant is created.
And I can't find a way to programmatically disable items in an Enum constant.
Is it possible?
(1,620 Views)
Is it possible?
I'm curious what the application would be, because I can't think of a reason why you would need to disable something on a BD constant.
Bill
CLD
(Mid-Level minion.)
(1,608 Views)
Is it possible?
There's a hint in the picture.  The typedef has "<Select>" as its 1st value; and that's never a legit value, not even on the BD.  Note also that you can manually disable items in an enum constant.
(1,576 Views)
Well, I learned something new today. (I fear I might learn this in the future again 😋 )
(1,568 Views)
Accepted by topic author paul_cardinale
Occasionally you can trick LabVIEW into applying front panel properties to their corresponding block diagram objects with the Type Cast function. This is one such occasion.
(1,565 Views)
