Is String constant display style visible per default?
I like the little indicator showing the display style of a string constant. I'm tired to switch its visibility on with every placed string constant. Is there a LabVIEW.ini - hack or some other way to place them always with the indicator visible?
Greets, Dave
(1,912 Views)
Accepted by topic author daveTW
you can create a 'Place VI Contents VI' and call it with Quick Drop when you need it.
See: https://forums.ni.com/t5/Quick-Drop-Enthusiasts/Quick-Drop-Keyboard-Shortcut-Create-Place-VI-Content... for more information.
(1,897 Views)
Try a typedef.
George Zou
(1,896 Views)
Try a typedef.
Maybe a control template is more appropriate?  (I've actually never used one before.)
Bill
CLD
(Mid-Level minion.)
(1,882 Views)
Control templates and type definitions (even strict) do not apply their style on block diagram constants, only on front panel controls.
I think using a Place VI Content is the only way...
(1,818 Views)
I doubt it is the only way.  But, I use exactly that method!  I never looked for another way since it is rather simple to implement.  😀
It would make a great Idea Exchange entry.
"Should be" isn't "Is" -Jay
(1,798 Views)
Oops, I missed "string constant".
Bill
CLD
(Mid-Level minion.)
(1,784 Views)
