Is Name Multiplatform.vi - why you're hiding from us?
Why "Is Name Multiplatform.vi" (vi.lib\Utility\libraryn.llb\Is Name Multiplatform.vi) is not avaiable in palette? This is quite useful VI for filename validation.
This is situation similar to "Check Prime.vi" subject... Darren maybe another CAR? 🙂
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(3,464 Views)
"Is Name Multiplatform.vi" was presented in Darren's Weekly Nuggets in 2010 in this forum thread: https://forums.ni.com/t5/LabVIEW/Darren-s-Weekly-Nugget-11-02-2010/td-p/1298866 and was not initially intended for widespread use.
You can look up Darren's response explaining what is the general policy on Public and Private scope VIs here: http://forums.ni.com/t5/LabVIEW-Developers-Feature/Issue-VIs-in-vi-lib-that-are-not-in-the-palettes-... and contact R&D or Darren in person if you believe this particular VI should be made public.
Piotr
(3,396 Views)
Accepted by topic author bienieck
Cross posted here, where I'll be posting a reply at some point.
(3,373 Views)
