Is Labview DSC 6.0.2 fully compatible with Labview 6.1
Is Labview DSC 6.0.2 fully compatible with Labview 6.1? If yes, are there any installation procedure that I should take note? Install Labview 6.1 first and then Labview DSC 6.0.2? After that, do I need to recompile the VIs or install any patch?
(3,987 Views)
I have noticed some timing issues in version 6.1 dsc engine, it appears to be slower than 6.0.2. I have been trying to develop a high speed data collection routine between a plc/opc server/dsc engine over an ethernet connection.
(3,987 Views)
If you update to LabVIEW 6.1 you also need to update to LabVIEW DSC 6.1. Sorry but there is no way to install DSC 6.0.2 in a LV 6.1 environment.
Jochen Klier
Application Engineering Group Leader
National Instruments Germany
(3,987 Views)
