Is Get Value By Pointer.xnode compatible in OSX?
I am searching some methods to import port audio(http://www.portaudio.com/) to LabVIEW for Mac OS,I found some functions in it's header files whose return is struct pointer,so i want to use the Get Value By Pointer.xnode,but LabVIEW crash when I click run button,wo can tell me is the xnode compatible in OSX? or we can get value some other ways?Thans!
(2,108 Views)
Which LV version are you using? May you please attach your vi too?
(1,990 Views)
Are you by any chance trying to map fixed size arrays in the returned structure to LabVIEW strings or arrays? That can’t work as fixed size arrays in C are more equivalent to LabVIEW clusters with the same amount of elements in it!
Rolf Kalbermatter  My Blog
(1,984 Views)
