Invoking remote VI's
I want to call a VI in a remote LabVIEW application. I use the Open VI
Reference to open a reference to the remote VI. However it seems like
this VI requires me to give a full path or ensure that the VI is already
loaded in memory if I provide only VI name.
How can I call a VI in a remote LabVIEW application if I only now the VI
name?
Regards
Jan Klasson
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,039 Views)
> name?
A hard disk can be a big lonely place. The best workaround is to orgnize
the VIs so that they are in a known place or in one of several known places.
If the VI isn't in one location, then the Open will fail with a specific
error, and you can check another location. This is not something that you
will want to do to every file on the disk. That would take much longer
than you probably want.
Another way to do this is t
o have in a known location an agent that can
do the search looking for the Vi file and return the file.
Greg McKaskle
(3,039 Views)
In article <387D3EEC.F850FAD9@austin.rr.com>,
VI
like
already
the VI
> > name?
orgnize
places.
specific
you
longer
> Another way to do this is to have in a known location an agent that
can
> Greg McKaskle
OK, thanks Greg.
However, I belive LabVIEW ought to supply a function for finding and
loading a VI by using VI search path. This would be much easier, and it
would be a natural solution.
In my app I can probably assure that the VI is allways loaded.
Regards
Jan
Before you buy.
(3,039 Views)
