04-04-2011 11:27 PM
Windows 7 64bit
labview 9, 32 bit
bug alert!!
see attached example vi's
The export image invoke node only works while the subvi is open, if called as a subvi and the subvi is closed this function fails to create an image.
Using the build XY graph express, I have created an xy graph. Then created an invoke node to export the image of the xy chart. When i call this vi as a subvi, it works, provided the subvi remains open. If I close the subvi and run the main vi, no image is created.
Any explanations why this would be so? Does labview 10 have the same problem?
Solved! Go to Solution.
04-05-2011 02:03 AM
That's not a bug, Read This http://forums.ni.com/t5/LabVIEW/Export-simplified-image-failed-in-subvi/m-p/950004
You will get an Explanation and what should be used.
AshwiN,
04-05-2011 05:33 PM
So the simple answer is, whenever an image is desired from a subvi always use : invoke node -> get image, in addition to whatever image gathering code already implemented to force labview to update the image
