Invoke Node System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. Inner Exception: System.Applicatio
Inner Exception: System.ApplicationException: Exception response in SetClassesResponse, code: 128 <append><b>System.ApplicationException</b> in Std_Bus_Write.vi->Standard Bus LabView Example.vi
I'm trying to connect to Watlow EZ Zone TEK Cascade Forced Air Oven and I get this error when I try to input a temperature to be taken by the oven. I can Read the temperature of the oven but I can't Write it. Any help would be appreciated. Thank you!
(1,857 Views)
Did you fix the problem? I am having the same issue.
(1,771 Views)
