Invoke Node Error
Good Morning,
I created a project with multiple VIs, my main Idea is running the whole project respectively through Next Button.
my project contain from the first Logo page >> Login Details >> Info Details >> Real Time Data Details and >> Adding new user.
through the Next Button, it work properly. I created a case structure and inside the true case ( i opened a VI reference using vi path, connecting to an Invoke node (FP-open) >> Invoke node (Run VI) then I close the VI reference and connected it to the error handling. in the False case i created something related to the case itself.
after that I created a Previous Button (Error Started here ) in the button i build same case structure i used to the Next Button but in previous order.
when I'm running my VI and move forward from Logo to other VIs it work properly, but when I start going backwards through Previous Button- I'm having an error called (ERROR 1000) - Not in a State Compatible with this Operation.
I read through the instruction, but I guess I'm having a blind spot that I can't figure it out yet.
Also how can i create a global variable to stop button, now if you pressed the stop button it will shut down the logo vi, i want to make it close the whole project.
so if you can suggest a solution to me will be great.
Cheers,
(2,900 Views)
just a very simple suggestion, try to have your post moved to the appropriate LabVIEW forum (Options / Report to a Moderator: please move my post), this one is for a different software product, LabWindows/CVI Smiley Wink
(2,871 Views)
hi there
Already asked for that.
i haven't notice when i posted it in the morning
(2,837 Views)
