Inverting a Block
Normally a block a labview has his input on the left side of the block and the output on the right side. But is it also possible to invert the block in that way that the input is now on the right side and the output is on the left side ?
Greetings
(2,858 Views)
I guess you could make your block a sub-vi - make the icon look similar to the function and wire the connector the way you want it
(2,858 Views)
I guess that's too much work. I need an easier way.
(2,858 Views)
Davy wrote in news:5065000000050000001F140100-1042324653000
@exchange.ni.com:
Why do you need to invert the block? Can you give an example of somewhere
that the existing system isn't doing what you want/need it to do?
Andrew
(2,858 Views)
