Intigrating the Instruments in labview
I Farley new to LabView,I am Working on High Power DC Auxiliary Trip Relay Test station Project,here I am going to use GEN-300-1.5 power supply because I have to drive 110vdc and 220vdc to UUT in this one I am not not able to get how program to  connect 2 different voltage terminal with single power supply and i need to measure the Conducting time between Relay which is my UUT here,how to measure the time of conduction of relay coil.here I am planning to use NI USB 6008,is it correct or suggest best.
Here I attched Manuval testing Design Snap,now i am going to convert it to automation.
(3,294 Views)
You are doing a lot projects in LabVIEW! Thats awesome
Certified LabVIEW Architect
(3,162 Views)
Dear Sir.
From last 4 month,I got 4 different project,this one is the 1st project where I started my LabVIEW development after completing my LabVIEW training, I planed to do this project with some PLC counter,but the execution of this project will start after 3 months,the one yesterday We discuss that project execution will be starting by next week only,
One problem Is that I am alone,no one is here to discuss and fix the queries and to give suggestion on LabVIEW.
Thanking You.
Raikar A G
(3,156 Views)
You are working with some potentially dangerous voltages.  And your English is a little rough making it difficult to understand your original message.  It looks like one long run-on sentence.
I suggest calling your local NI sales representative and have them discuss your project with you.  I'm sure you'll be able to get it to work with LabVIEW, but you need to have the right selection of hardware.  I'm not so sure a USB-6008 is the right choice as it is one of the more basic DAQ devices, and it certainly can't interface directly with 120V or 240V AC sources.
(3,150 Views)
Dear Sir.
Ya I tried with Local NI people,even i got training from National Instruments.
I am not going to use DAQ card in this project.
Raikar A G
(3,148 Views)
Then what are you using?
You had said "I am planning to use NI USB 6008, is it correct or suggest best."  Now you are saying you are "not going to use a DAQ card in this project."
(3,137 Views)
