Interprocess Communication Pass-by-Reference
Ben wrote:
nathand's above described method is my favorite.
TCP/IP is also available if you are more comforatable with that.
Ben
VI Server is also using TCP/IP to communicate with out of process remote instances. Smiley Very Happy
But of course it hides quite a bit of the complexity of packing data together that you would have if you do your own TCP/IP protocol.
Shared memory while indeed a possibilty under Windows (and Linux with a very different API)is indeed a bit painful to use since you have to interface the system API for that, and access to the shared memory is a bit painful too from within LabVIEW. It is likely the most performant version of interprocess communication though.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 11 of 12
(865 Views)
nathand (and Ben),
Thanks for the information; it sound like what I'm looking for.  I'll try it out as soon as possible.
Best Regards,
Chris
Message 12 of 12
(853 Views)
