Interpolate intensity graph
Hi guys, I was just wondering whether anyone knows how to use the interpolate function with an intensity graph. I want to use it so my results can look "smoother". I have attached my code to this email- is it possible to include the interpolate fuction within this code? Thanks.
Message 1 of 16
(5,196 Views)
Well, you only have 16 elements, so what do you expect?
You can respame the image at a higher resolution using bilinear interpolation. here's an old example.
There is even one of my ideas that suggest native LabVIEW support for all this. Of course you also might be able to use 2D interpolation. What have you tried so far?
Message 2 of 16
(5,183 Views)
Hi
Message 3 of 16
(5,181 Views)
Have you looked at the example I linked above?
Message 4 of 16
(5,178 Views)
Hi
Message 5 of 16
(5,147 Views)
The subVI only generates one point. You need to loop over a new 2D grid as shown in the linked example.
Message 6 of 16
(5,140 Views)
Hi altenbach, would just like to say this issue has been resolved and I have been able to interpolate my readings. Just would like to know how the example works, in depth. Although it has worked, i would like to knowhow it it works. You provided a brief explination, just wanted to know whether you can go into further detail? thank you
Message 7 of 16
(5,088 Views)
Bilinear Interpolation
Message 8 of 16
(5,085 Views)
what does the "ramp by samples" VI mean? and the reason why the reason why you have the code in 2 loops is because the subVI only generates one point?
Message 9 of 16
(5,055 Views)
If in doubt about a function: Right-click...help!
Yes, we need to do it for each point in the new grid.
Message 10 of 16
(5,053 Views)
