Internet Config button AuthUserFile hangs program
LabView, Tools Menu. Select item, Internet Toolkit Configuration.
Click button, Access Configuration.
Click button, Edit Directory.
Click button, Authorization.
Click pencil button to edit "AuthUserFile."
Labview now brings up a file selection dialogue box that will not go away: if you try to cancel or click on save, the dialogue comes back up. You cannot access any other part of LabView.
(3,054 Views)
Give
this KnowledgeBase [broken link removed; article no longer available] a try.
(3,054 Views)
I had already seen that article. Apparently it applied to LabView 5.0. In any case, I could not follow the directions in the KnowledgeBase article because the files described did not exist on my workstation. Under 6.1, there was no file LabView 6.1/internet/config/password.llb, so I couldn't change any settings.
My guess is that LabView 6.1 has the same problem as the 5.0 did again, but the settings to fix it have moved. Help!
(3,054 Views)
