Internal functions of Labview ?!?!? ( Closing Function )
Hello Everyone !
I need a function in Labview which should close the test case right after it is finished...Is there such a function that exists ????!!!!?!?!?! if yes where ?
thanks alot
(2,535 Views)
What do you mean by "test case" ?
If you need to stop the execution of LV or close LV itself, you can use the Stop or Exit functions in the "Application control" subpalette. But a well planned application should not rely on these functions as method to quit a vi...
Chilly Charly    (aka CC)
(2,532 Views)
You need to tell us what you mean.
You can have a VI "Show Front Panel when called", and "Close Afterwards if original closed". Look in "VI Properties", under "Appearance", and choose "Customize".
If you ask a clearer question, you'll get a clearer answer.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(2,509 Views)
