Internal error or labview crash in 7.1ver thread.cpp(2842) whats reasons and how to fix it
Hi
Everybody ,
I am working with pci-6723 and labview 7.1 yesterday when iwas testing , the programme was running , suddenly the power has gone , since i have not connected my system to UPS system got shutdown , and when i booted pc its higlighted this error , now to what extent this problem affects to my software, and how to fix it.
"Internal error or labview crash in 7.1ver thread.cpp(2842) whats reasons and how to fix it"
Thanks in advance
Rajesh
(2,582 Views)
Hello Rajesh,
Do you get this error frequently or you got it only once after the power shutdown? Are you making a call to a DLL in multithreaded environment? Try mass compiling the VI by going to Tools->Advanced->Mass Compile. Also please follow the suggestions provided in this knowledge base entry regarding thread.cpp and see if that will fix the problem:
http://digital.ni.com/public.nsf/websearch/01B186B5CEB1D07786256747000F4319?OpenDocument
If you continue to have this error, is there any way you can send me a pared-down example demonstrating what your program does, so I can at least investigate to see if I can narrow down the cause of the thread.cpp failure?
Thanks and good luck!
Shakhina P.
(2,557 Views)
