Internal error menu.cpp#92 line 3075
I tried to import my old instrument drivers and recieved an internal error message  .\manager\menu.cpp(3075)  :DWarn: Itempos 4 out of range [1..3]
$Id://labview/branches/Constellation/dev/source/manager/menu.cpp#92 $
(3,252 Views)
Hi K Cobb,
I have the same error. Is nasty isn't? Smiley Mad
But my happened when ever I right click on any Controller or Indicator in both front panel and diagram.
If you know the fix please let me know. ThankSmiley Very Happy
Attached is the Error meassage:
(3,220 Views)
If you encounter this error, please follow the instructions given for sending an error log to NI. Also, if the error is consistently reproducible, please include any steps to follow or example code that demonstrates the behavior.
Kind Regards,
E. Sulzer
(3,211 Views)
Hi E. Sulzer
Thanks for that.
Yes, the problem is re-producable every time. Already report to NI. The message I get from NI as below
I'm really sorry to say that there isn't much we can do about the problem you are experiencing. The error has been encountered by a few users before, and the issue is being fixed in the next update of LabVIEW. I wish there was a workaround for this problem for me to provide you other than using another computer.
Andrew Young
Applications Engineering
www.ni.com/support
(3,204 Views)
