Intermittent TDMS error 6
LV 8.5 (XP Pro) sporadically generates the following error when defragmenting a TDMS file stored on the local HD:
Error message: Error 6 occurred at TDMS Defragment in <VI that contains the TDMS Defragment VI>
Possible reason(s):
LabVIEW:  Generic file I/O error.
Similar question was posted back in 2006 but wasn't resolved
http://forums.ni.com/ni/board/message?board.id=170&message.id=211469&query.id=1178248#M211469
Any ideas what could be wrong?
(3,250 Views)
Hi sukaba,
Could you please try to use the TDMS Defragment primitive node directly? If you still get the same error, could you please check whether the file is read only?
(3,241 Views)
Thanks for your reply.
I am using the TDMS Defragment primitive.
The TDMS file is not read only and there is plenty of space on the local HD.
As I mentioned the error is intermittent.
Cheers
(3,201 Views)
Thank you for finding this problem. We are willing to look into it.
To make the problem more clear, is it possible and convenient for you to attach your VI on the forum?(A snapshot or a simplified one is also helpful). We will try to reproduce it on our machine and fix it.
(3,179 Views)
