Intermittent Save Report to File error
In my program, regularly I will get the error below from NI_report.lvclasss:Save Report to file.vi.  I digged deeper, and I found that the error comes from a SaveAs method under _Workbook inside the NI_ReportGEnerationToolkit.lvlib:Excel_Save_Workbook.vi.  Its input contains Filename, Password, and FileFormat.  The Filename is 199 characters, the FileFormat is -4143 for .xls and Pasword is blank.  I thought the number of characters is a bit suspicious.  If it is a problem, howcome the error is not consistant?  How do I get over that limitation?  I thougth window 7 allow at least 250?
Error -2146827284 occurred at Unknown System Error in NI_ReportGenerationToolkit.lvlib:Excel_Save_Workbook.vi->NI_Excel.lvclass:Save Report to File.vi->[TSV2 File] - Save Event Log Result File.vi->[TSV2 File] - Create Event Log Result File.vi->[TSV2 Analysis] - Analyze Event File.vi->[TSV2 Test System] - Main.vi
This error code is undefined. Undefined errors might occur for a number of reasons. For example, no one has provided a description for the code, or you might have wired a number that is not an error code to the error code input.
Additionally, undefined error codes might occur because the error relates to a third-party object, such as the operating system or ActiveX. For these third-party errors, you might be able to obtain a description of the error by searching the Web for the error code (-2146827284) or for its hexadecimal representation (0x800A03EC).
(3,156 Views)
Have you done what the error code told you to do? Checked the web?
What did you find?
What have you tried?
Mike...
PS: why is the file name length suspicious? What is the usual length of your file names? What is the name that is being generated?
Certified LabVIEW Architect
LabVIEW Champion
(3,137 Views)
I did a search on the decimal error code, but I didn't find much.  However, after i read your message,I did a search on the hex error code, and I found much more.  It seems like the problem is due to the fact that I am saving the file in *.xls instead of *.xlsx, but the proposed reasons that I found on my reserach are not the cause of my problem.  I was actually save file in *.xlsx, and there was an excel problem that was resolved when save in *.xls.  I forgot what problem it was though.
I was looking at the code and I saw that it did a blank save to creat the file and save again after the file is populated with data.  The 1st save looks suspious, so I removed it, and I hope it will solve the problem.
I just thought that the length is suspicious beacuse the lenght is 199.  It look like it is at some sort of limit.  The usual lenght of file is about 190.
(3,110 Views)
