Intergration
I´m looking for an integration function that can integrate partially out of an DAQ assistant. Does anyone know which function I can use for it?
(3,144 Views)
Well, if I understood correctly I'd say you can use an "Add array elements"
You can find it at numeric palette!
Sorry, if I understood it wrong!
(3,141 Views)
Theres a numeric integration.vi in mathematics >> Integ & Diff
I assume this is what you mean...
_________________________________________________________________________________________________
That glass?
Thats glass is neither half full or half empty....
Its twice the size it needs to be
(3,137 Views)
The functions palette has a search capability. Have you tried it?
Message Edited by smercurio_fc on 06-04-2010 09:12 AM
(3,123 Views)
Integration function is added to a express VI with a lot other functions, please have a llok at the time domain express VI, this can be found under express => arithmetic & comparison. Instead of express VI's you can also find DAQmx examples with the example finder and add the conventional function to the example. Please open the example finder and find tha analog input examples under browse => hardware in and output => DAQmx analog input.
Martijn S
NI Netherlands
(3,082 Views)
