Interfacing with C Program to read camera - how do I keep an open session?
I'm fairly inexperienced and working on a project in which a camera is attached to a moving X-Y stage. The goal is for the camera to track worms moving below in real-time, then follow them. The camera is a Basler A601f with an IEEE1394 interface. I think this would work with IMAQ, but the software that controls the motors is Linux-only, so that's not an option. It seems my only choice is to use the functions of a C library (libdc1394) to read the camera. Here's my question:
The library creates a "camera session," initializing a bunch of stuff, then starts a video feed to a buffer. The easy solution would be to write a C program that initializes the camera, takes one picture and outputs it, then cleans up the camera session. I could call this program repeatedly in LabVIEW. However, I feel like the repeated initializations would have a bunch of overhead. I would prefer to have a C program running in the background, so I could periodically poll the buffer from LabVIEW to get the latest picture. I can't really think of a way to do this with just the "Call Library Node." Is this possible, and how would I do it?
I tried to keep the post pretty simple, so if you need any more information, please ask. Thanks!
(5,091 Views)
Thanks for trying to keep the post short, but there's not enough information to answer your question.  What functions does the library provide?  Is the session a parameter that you pass to each call to the library?  There's no reason you should need to open a new session for every image, but it depends on how the library is structured.
(5,083 Views)
As I was writing this post, I realized that this might be a dumb question. For some reason, I was under the impression that LabVIEW couldn't handle C pointers, so I would have to make a wrapper function around the library. But I didn't know how to keep this wrapper function in memory - you'll see later in the post how this would be a problem, since you need to get a handle for the camera in order to take pictures, so if the program closed, you would lose the handle. But turns out LabVIEW can use pointers, so I probably won't need a wrapper function at all! So hopefully this won't be a problem.
OK, here's the basic form for running the camera:
Library initialization:     d = dc1394_new ();
Get list of cameras:     dc1394_camera_enumerate (d, &list);
Initialize camera:     camera = dc1394_camera_new (d, list->ids[0].guid);
Release list of cameras: dc1394_camera_free_list (list);
Get list of video modes: dc1394_video_get_supported_modes(camera,&video_modes);
Pick a mode: dc1394_video_get_supported_modes(camera,&video_modes);
(Similar to get framerate and other parameters)
Set camera speed:     dc1394_video_set_iso_speed(camera, DC1394_ISO_SPEED_400);
(Similar to set mode and framerate)
Tell camera to start transmission:     dc1394_video_set_transmission(camera, DC1394_ON);
Take a frame from camera buffer: dc1394_capture_dequeue(camera, DC1394_CAPTURE_POLICY_WAIT, &frame);
This is the step that actually grabs the picture, so it would be in a loop. After that, data transmission is stopped, the session is closed, etc.
I'll bump the thread if I have more trouble. Thanks.
(5,079 Views)
