11-01-2012 04:24 AM
Hi..
I am using NI starter kit containing SbRIO-9632 and programming it through Labview..Now if I want to interface external gripper to it, I am using servo motor for its motion but how it is possible to program for this external motor in Labview..I mean Do I need to make some pin high in SbRIO??
Pls help me to start..
11-01-2012 05:02 AM
Getting started with your NI hardware/software:
http://www.ni.com/gettingstarted/
Check out the NI Community robotics forum for lots of examples:
https://decibel.ni.com/content/community/zone/labviewrobotics?view=documents#/
Br,
/Roger
11-08-2012 12:41 AM
Thanks RogerIsaksson for your response..
I went through your suggestion and examples link. But I am not yet clear with my question.
As I want to control servo from my sbrio-9632, I will connect 2pins of my servo motor i.e GND and Digital input pin to my sbrio. I will give +5v supply externally. As there is no any particular PWM pin in sbrio , I will have to connect my motor input pin to PORT/DIO pins in Sbrio. So my question is - is it right? Whether it will be enough to connect input pin to PORT/DIO pin and code something in my labview to generate PWM out of it? OR I will compulsary need some NI driver modules to drive my servo..for eg NI 9505 module..
Please help me. And also if whatever I am thinking to do is right, how to write a PWM code to drive my motor??
Thanks once again to help.. Kindly reply further.
01-07-2013 02:58 AM
Hi sharry,
You should be able to connect the signal pin of your servo directly into one of the Digital Pins of the SB-RIO. Then you can simple write a pulse of varying width using the FPGA to drive the servo. A good example of this can be found in the Example Finder. Simply search for "PWM", the example you want is called "Controlling a servo using PWM.lvproj".
The 5V and GND pin of the servo should be connected externally, so that the servo doesn't draw its power from the SB-RIO.
Also be aware that the digital pins on the SB-RIO operate at 3.3V, not 5V. So if you're outputting a pulse to control a servo, it will be a 3.3V pulse. For most servos, this won't be a problem (3.3V is within the range for a HIGH signal in TTL and CMOS logic levels), but it's worth checking the datasheet with your servo first, or doing a quick test,
Kind regards,
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
