Interfacing MS Project in Labview
Hi All,
I've seen that Labview can interface with Excel, Word, and Powerpoint but can it also interface through MS Project? For instance using an ActiveX control.
Any examples welcome
Kind Regards
Richard
(3,849 Views)
Hi R Dunn,
I hope you are well and thank you for using the National Instruments forums!
I am not 100% familiar with MS Project, however if MS Project allows ActiveX control, you can essentially embed any ActiveX control within LabVIEW itself.
I have included some documentation to help you get started with using ActiveX and LabVIEW
Developer Zone: ActiveX and LabVIEW - https://www.ni.com/en/shop/labview/activex-and-labview.html
I hope that helps!
Ashish Naik
Automotive Business Development Manager
National Instruments UK
(3,816 Views)
You may need to experiment with the Active-X on this one.  I don't recall anyone implementing this solution.  Hopefully MS can provide some documentation on the API (or Active-X).  I will do a search in case something was already done for MS Project.
(3,803 Views)
