Interfacing Analog Device ADIS16488A with NI-CRIO LabVIEW
Hello All, can I interface adis16488a IMU with NI-CRIO? and I also look at some code or driver in LabVIEW which can use for IMU data acquiring
(2,798 Views)
Hi amit,
this IC supports communication over SPI.
Have you looked for SPI communication with cRIO?
(2,767 Views)
Hello Sir,
Yes, I am looking for SPI communication with cRIO. Can I directly interface with cRIO or I need some other device like Arduino or some SPI to a USB device for communication.
(2,755 Views)
Hi amit,
using a DIO module with sufficient high sample rate you could implement the SPI communication on your own in the FPGA.
Using some Arduino boards (maybe with network communication) might be simpler…
(2,750 Views)
