Interface terminator problem
I'm running a VI and controlling a 2400 series Kiethley source meter, using GPIB-USB-HS interface.
(Using LabVIEW full development 2015.)
I continually get the error condition.
-410, “Query INTERRUPTED”
Which I can only attribute to incorrectly configured driver.
If I go to NI-MAX , I don't seem to be able to configure to the  terminator conditions.
Would somebody happen to have a complete description on configuring this driver for the following:
The driver must be configured so that when talking on the bus it sends line-feed with EOI as the terminator,
and when listening on the bus it expects line-feed with EOI as the terminator.
Is there a possibility this is facilitated directly in the VI?
Thank you
(2,128 Views)
Please post the VI you are referring to. These kinds of settings are usually set when opening the instrument communications.
(2,100 Views)
