Interface Block Diagram
HI
I am developing an interface for my application and my application stucks in a while loop for ever.
1)My program runs fine if I use one Tab control.
2) As I put the second tab control it stucks in loop.
I have to toggle between different pages of tabcontrol using buttons.
Regards
Malik
(4,008 Views)
You are having problems because you are using 2 event structures - you should only include 1 in each VI. Every event structure registers for events that could occur, so when an event does trigger both structures will attempt to handle it, causing one to lock up as you are experiencing.
_____________________________
- Cheers, Ed
(4,002 Views)
Accepted by topic author arrowminds
yenknip wrote:
You are having problems because you are using 2 event structures - you should only include 1 in each VI. .
I disagree. You can use as many event structures as you like. Your problem is that they are in the same loop. if you put one, in another loop everything will be fine.
(3,978 Views)
I agree with Pnt, and so does (at least one) someone at NI.
Jim
(3,969 Views)
It is pretty simple logic if you think about it. There really would be zero reason to put more than one event structure in a single loop anyways because you can add every event that needs to be checked for, as the loop iterates, into that single event structure.
Message Edited by for(imstuck) on 03-06-2009 08:48 AM
(3,960 Views)
"jcarmody" <x@no.email> wrote in message
news:1236350407835-866032@exchange.ni.com...
> I agree with Pnt, and so does (at least one)&nbsp;<a
href="http://zone.ni.com/reference/en-XX/help/371361D-01/lvhowto/twoevntstrc
tonelp/" target="_blank">someone at NI</a>.
That is why the put it in the help...
(3,931 Views)
