Intensity Graph - Same color, 2 different markers
Hi all,
So I have intensity graph A. It represents the difference between two data sets at each (i,j) point. 0 is the best, where both data sets completely agree... and then +/-10 are the max and min agreement values.....
I have created 5 markers.... (-10,-5,0,5,10) and want the 0 green, +/-5 yellow, and +/- 10 red. I set the marker values to those colors using the property node: ZScale.MarkerVals[] linked to a cluster with the above values and colors. However, no matter how much I run the code... it is stuck in previous colors and wont change from rainbow to the red->yel->green->yel->red sequence I want.
(2,747 Views)
Accepted by topic author Jewsus
Hi Jewsus,
it works for me:
When you have a problem with your VI you should also attach your VI.
Images of (part of) the block diagram are hard to debug!
(2,726 Views)
Sorry for the late reply, had this issue at the end of my work day.
I think I figured out what my issue was. When originally creating the intensity graphs... I simply clicked ctrl + drag on the graphs to create a few extra. Apparently labview doesn't like this in combination with Property nodes as the original property node seemed to constantly still affect the copies.
I went through and just recreated the intensity graphs through the menu option instead and the property nodes are properly working now. Thanks again GerdW
(2,656 Views)
