Integrator control with timed loop
Hi all, when dealing with discrete time control like the poleplacement method, the sampletime shouldn't necessarily be
as short as possible like in "analog" PID-control.
I want to be able to set the time of how often I am sensing the input and therefore I am using a timed loop.
Something is missing in my file because it won't work.
The propertynode DigNum is not inserted by me, but by the png-software. I have a local variable there refering to the period dt.
Kindest regards,
Lasse
(3,898 Views)
Hi Lasse,
"Something is missing in my file because it won't work."
Yes, the error description is missing. What is wrong? What exactly doesn't work?
- Instead of using locals you could use a wire or the block in the upper left of the TimedWhileLoop to get dt from it...
- Does the loop spin as fast as you want it to spin or do the ExpressVIs slow down the execution?
(3,896 Views)
Oh sorry for that.
Nothing happens.
(3,883 Views)
Hi Lasse,
as the waveform graphs are empty it seems you don't get any data from your DAQassi!
You're using the channel "Voltage" in your DAQAssi1 - and we aren't able to check your settings...
(3,879 Views)
Hi all, and thanks for your patience GerdW.
I am using "1 Sample (HW-timed)"
The reason is that I've seen controltutorials where they use a while-loop with "1 sample (SW-timed)" to get a variable dcvoltage, when no control over the time is needed.
Since I am using a timed loop, I supposed that I can use "1 Sample (HW-timed)".
regards,
Lasse
(3,874 Views)
Hi Lasse,
"Since I am using a timed loop, I supposed that I can use "1 Sample (HW-timed)"."
Why do you think so? You still use software timing, it's just a slightly different loop construct...
When using "HW-Timed" access you have to define the sample rate before starting the task!
(3,867 Views)
