Integration using the Time Domain Math Express VI
Hello, I am new to LabVIEW so please pardon this possibly simple question.
I have searched around and I can't figure out the timebase (dt) for the Time Domain Math Express VI integration function.
I am trying to use it to integrate an acceleration waveform, and I need to understand what the timebase is so I can calculate the units of the output value.
Thanks in advance!
Message 1 of 9
(4,692 Views)
A waveform datatype already contains timing information.
Message 2 of 9
(4,690 Views)
So how do I determine the units of the output if I was integrating for example, instantaneous power to get power used over time?
Message 3 of 9
(4,688 Views)
The units will be the units of Power times the units for time.
So if your power is Watts, and the dT is seconds.  The it will be Watt-seconds.
If the power is kW and the dT is based on  hours, then it will be kW-hrs.
Message 4 of 9
(4,679 Views)
Thank you for the reply. I understand that, and I guess I should have been more clear about what I was asking. What I don't understand is how to determine what dt is. Is it seconds, miliseconds, microseconds? How is it determined? Is it based on the time it takes to execute a loop?
Message 5 of 9
(4,675 Views)
dT is technically just a number as far a LabVIEW is concerned.  If it is 1, then it is 1 unit of time interval.  If it is .001 then it is a thousandth of a unit.  What the size of the unit is depends on where the data is coming from.  Typically if you are dealing with Waveform datatypes, and you are getting data from a DAQ device, the unit is practically seconds.  So a dT of 1 on a DAQ card would be 1 second.  A dT of .001 would be 1 millisecond.
Message 6 of 9
(4,666 Views)
So if I am using the DAQ Assistant to collect waveform data, will the dt be 1/ the sampling frequency? Does it depend on n (the number of samples per cycle in the DAQ Assistant)?
Message 7 of 9
(4,652 Views)
I would think it dt always in units of seconds.
Message 8 of 9
(4,649 Views)
dt has nothing to do with the # of samples, it's the rate at which the data is sampled, dt = 1 / Fs.
Message 9 of 9
(4,644 Views)
