Integrating values between cusors
Hello All,
I am trying to intergrate the values of an array that lies between two cursors on a dynamically updataing XY plot. When I use a property node to get the cursor index, the leftmost point on the plot is 0 as expected, but the very next point on the right has a value like 86325. I have no idea what is happening. Can someone point out what is wrong here?
What I want to do is have a xy plots, allow the user to drag the cursor to the required point on the plot and display the sum of the array contained within the plot.
Thanks.
KB
(2,485 Views)
Hi Grass,
if you look in the history of this posting, you will find someone, last week how developped exactly what you want to do.
Doc-Doc
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(2,485 Views)
