Integrate Labview with SPICE
I want to integrate Labview with SPICE to measure analogue voltage. I am unable to find a way out and looking for help.
(3,712 Views)
SPICE is a simulator for circuits.  DAQmx (and appropriate hardware) can be used to measure analog voltages ("real" volts).  If you do a Web Search for SPICE Simulation LabVIEW, you might come across this reference which mentions NI MultiSim, National Instrument's SPICE routine.
Since it isn't clear from your post what you want to do, I suggest you do some Web searching (check out the reference noted above) and see if this provides answers to your questions.  If you still need help, try to ask more specific questions so we can give more specific answers.
(3,671 Views)
