Integral for PI controller? Why the value has been magnified?
I want to build a PI controller using the original form, which consists the Proportional and Integral function. I chose the function "Time Domain Math". I  selected the Integral (Sum[Xdt]) and continuous calculation. When I did the testing, I found that the output value has been magnified. In my program I used a sine function the test the Integral function. The magnitude of input is 1 and the output become 320. Could anyone help me? Thanks!
Note: For testing purpose, in my program I use different input signals for P and I functions. For my understanding, I can have the PI controller, if I make the same input for P and I function and the sum the result.
(2,974 Views)
It's no wonder since all you are doing is integrating the sine wave's amplitude over time and adding some constant (P side) to it.
What you have is not a PI controller. Where's your feedback, error and setpoint terms? In control theory, for a closed loop system, the P and I gains are applied to the error (difference between the feedback and your setpoint) and then summed to give a new control output which (hopefully) reduces the error.
There are a lot of PID tutorials on the web. My suggestion is to take advantage of them.
(2,961 Views)
Hi Bill@NGC,
I agree what you said. But There are two points I need to mention. Firstly, It is the structure of the PI controller. It just has two parts the Proportional and Integral function if I don't consider others. Secondly, the program I attached is part of the control scheme. I test my program and found errors, so I break the whole program into piece. Then I found this magnified value. So I make this simple test to integral a sine signal. For ordinal condition, this sine signal should become cosine signal after integral function with same amplitude. But the result has been magnified, and I have no clue.
(2,955 Views)
I thank I should to ask this question in a different way. I actually want to know the procedure of the integration. For example the integral of sine signal between 0 to 90 degree, is -cos(pi/2)+cos(0), which is 2. But the signal generated from my program become far larger than this value. I don’t know what cause this and I am confused. So please anybody can give me a suggestion? Thanks!
(2,925 Views)
