11-01-2009 03:49 PM
Hi, I am using Labview 8.2 and I am trying to integrate a
60 Hz sine wave coming from a AC power source ( via DAQ).
My question is how do you set the value of dt within the integral x(t) vi?
Whenever I set this value (lets say 0.016) and run the vi
continously it automatically sets back to zero.
PJ
PJ
11-01-2009 05:39 PM
11-01-2009 08:20 PM
It also makes no sense to use 0.016 as dt. dt is the sampling interval, not the period of the waveform. I suppose one should ask: do you know what an integration of a waveform is? It's basically the area under a curve. There are various numerical methods to implement this on a computer, with the trapezoidal rule being one of the simplest.
Also, integrating a sine wave just gives you a cosine wave - i.e. a phase shift. More specifically, it's -cos(x) + C, where C is some constant. That's just simple mathematics.
