Integer and a string arrays to LabVIEW from Matlab script node
I need to pass an integer and a string array to LabVIEW from Matlab script node. The latter only allows real and complex vectors and matrices as output nodes. Can someone suggest a work around?
(4,954 Views)
Hi
I do not know if this helps but maybe divide every string to
chars and send array of chars (converted to int16) and in Labview
put it once more together.
P.S. Next time you write to newsgroup give at least your name, it
is better to know hwo you are talking to.
by
PP
(4,954 Views)
Many thanks for taking time to answer,Pawel. I did try this(both with I8 and I16 as output) before posting here. I am attaching a test VI which did not work. I would be grateful for any further help.
Thanks again
Sheela
(4,954 Views)
I modified the example you posted to utilize the double command in Matlab. It should now do what you want.
Matt Kisler
(4,954 Views)
I had 4 strings in a variable.
how can i get that as output
(4,293 Views)
