12-13-2011 06:05 PM
I have a GPIB resource. It is showing up in MAX, but not in resource name constant. I checked I/O filtering and refreshed the resource name, but the problem persist. What's happening? See attached picture.
Solved! Go to Solution.
12-13-2011 11:04 PM
Try the Select VISA class menu item just above I/O filtering in the right click menu.
12-14-2011 09:51 AM
I tried that. The resource still appear in MAX, but no in a resource name constant of my LabVIEW.
12-14-2011 03:05 PM
There is a good resouce on the NI website that describes how to handle the exact situation you seem to be encountering. You can get to that page by following this link:
http://digital.ni.com/public.nsf/allkb/61BA81FB87962275862574FA006F4815
Hope This Helps,
Doug B
12-15-2011 10:44 AM
I tried some of those approachs, but they are not what I am looking for. It seems like even though the resource does not show up on labview, and I am still able to talk to it if I key in the resource name manually. The USB-GPIB instruments are the ones that gave me problems, since I would know the primiary address of the instruments but not their interface ID. They are using different controllers.
I wrote a vi that loop through interface id 0-4 with a specified primary address to issue the *IDN? command and check for response. Through this method, I am able to find the address string of the GPIB and talk to the instruments even visa can't find that resource.
I hope that this method will hold up through time.
