Instrument IO Assistant is not installed correctly
Hi
I am using LabVIEW 8.6, and I want to use Instrument I/O assistant in the code as attachment. but it shows "measurement & automation explorer or the instrument I/O assistant is not installed correctly. please install these form the LabVIEW driver CD".
I've installed dcd-aug08-1 and could not find dcd-aug08-2.
I tried to use "instrument I/O assistant" in another code, and it worked!?
Please  give me some suggeation
Thanks very much
cynitha
(3,858 Views)
actually I want to change the source from "simulate signal" to signal of NI USB 5132. I tried "Instrument I/O assistant" but failed.
NI USB 5132 can run well in my laptop.
Could any one give me any suggestion?
Cynitha
(3,837 Views)
That does not make any sense to me. The 5132 is a scope card, has no signal, and is not a source. If you want to use the 5132 to capture something, you would use the NI-Scope driver. These functions are on the Instrument I/O>Instrument Driver palette if you installed it.
(3,831 Views)
Plz check Modular Instruments, Data Acquisition, Instruments Control when you install NI device driver DVD.
USB-5132 >> Modular Instruments>>NI-Digitizer
(3,817 Views)
