Instrument I/O Assistant problems
I am having trouble using the I/O assistant through my parallel port.  It is not writing to it.  The VI example, Parallel Port Read and Write Loop, works just fine.  Is there a way to use the I/O Assistant instead?
Ryan
(2,669 Views)
Hi Ryan,
What sort of problems are you having?  You should be able to use the Instrument I/O Assistant to communicate through the parallel port.  This tutorial, Instrument Control in LabVIEW Tutorial, shows how to set up the I/O Assitant.  If that's not working properly, what errors are you seeing?  Have you run NI-Spy to see where those errors are occuring?  Are you sure that you are sending the correct termination?
Let me know if you need any other help,
Meghan
Message Edited by Meghan R on 07-10-2007 02:26 PM
(2,655 Views)
